Water under starboard couch?
MartinRise
Your Country: Danmark, Hou/Jylland
Post by MartinRise »
Hi!
We just bought a great Dragonfly 1000, (hull #4) but it seems to be leaking a bit - water seems to leak down under the white foam padding, and creap out under the seat on starboard side!
What to do? Anyone else experienced the same problem? Is it the windows and can we tighten/seal them?
Kind Regards,
Martin Rise
Tolerance Hull #4
First off, welcome aboard! and the best of luck with your new boat!
Should be an easy fix, try tightening the screws in the cabin side windows.
That did the trick on my boat. Notice if there is a little white residue below the windows. If it is there, that is the reason.
