Top stay fittings
Stefan Kolmodin
Your Country: Sweden, Varmdo
Top stay fittings
Post by Stefan Kolmodin »
I bought 800 #257 last summer and found cracks in the mast alumimium profile by the top stay fittings in the mast. I will fix it with new fittings inside the profile and repair of the cracks.
Advice other owners to carefully check this on your boats, before it's beyond repair or worst case mast is coming down.
Stefan Kolmodin
Fixed it with new internal fittings and new aluminium plates on the outside of the mast - stronger than new, but I was very close to loosing the rig if I hadn't seen the cracks.
philw
Your Country: UK, Poole
Post by philw »
Hi Stefan,
Glad you found the problem in time.... Thanks for sharing your experience.
Phil
Phil Wheeler
DF800 185 - Trilemma
Poole, UK South Coast
