Removing headliner in toilet
jerry99
Your Country: Switzerland, Fribourg/ FR
Post by jerry99 »
The handrails on main hull are leaking. The right side I managed to demount after removing the plywood cover. But on starbord, the foremost screw is hidden by the inner headliner. I tried to remove the headliner without destroying it. But I have any clue how to succeed.
Has anybody removed the headliner without damage?
Thx for every comment.
DF 920E SUI-118, Lilly Belle
Fritz
Your Country: Germany, Schleswig
Post by Fritz »
I also had water ingress in the forward cabin, however it was leaking through the solar panel screws. To dry the sky in that area I cut it on either sider with a sharp knife. After drying, I screwed small wooden strips on either side thus fixing the sky.
If more questions - contact me in German.
Have a happy day on the water!
Fritz
jerry99
Removed all
Post by jerry99 »
Dear Fritz
Thanks for your comment.
I solved the problem radical: cut out the whole inner ceiling. I will replace it wit a insulation, for the places where further access is needed, I will cover, so in future I do not have to remove the whole ceiling by water ingress.
