1) If you encounter a pair of 12v wires that are blue and brown: Blue is negative and brown is positive.
2) If you need to run (or trace) wires forward from the main switch panel to the head and bow areas: There are three plastic (PVC) conduits that run from the main switch panel to the rear of the bathroom "medicine cabinet" (with the sliding tinted acrylic doors). You can remove the wood panel at the back of that cabinet with just two screws and access those wires. From that point forward there are two more conduits that run forward -- one to the AC circuit breakers and one to the bow locker (for the bow light).
3) If you are making up a three-point bridle -- the lines that attach to the outer ends of the forward cross beams should be 3 feet longer than the line to the bow cleat. I use a 20-foot center line and 23-foot port/starboard bridle lines. Using that as a guideline, the line to the center hull will be slightly slack unless one of the side attachments fails, and it will serve as a backup.
A few things DF-1200 owners may want to know
Return to “DF1200 Motor/Equipment/Electrics”
Jump to
- General Dragonfly Trimarans User Forum
- ↳ General
- ↳ HULL issues concerning all DFs
- ↳ Rig/Sail issues concerning all DFs
- ↳ Motor/Equipment/Electrics issues concerning all DFs
- ↳ E V E N T S
- DF25
- ↳ DF25 General Topics
- ↳ DF25 Hull
- ↳ DF25 Rig/Sails
- ↳ DF25 Motor/Equipment/Electrics
- DF800
- ↳ DF800 General Topics
- ↳ DF800 Hull
- ↳ DF800 Rig/Sails
- ↳ DF800 Motor/Equipment/Electrics
- DF28
- ↳ DF28 General Topics
- ↳ DF28 Hull
- ↳ DF28 Rig/Sails
- ↳ DF28 Motor/Equipment/Electrics
- DF920
- ↳ DF920 General Topics
- ↳ DF920 Hull
- ↳ DF920 Rig/Sails
- ↳ DF920 Motor/Equipment/Electrics
- DF1000
- ↳ DF1000 General Topics
- ↳ DF1000 Hull
- ↳ DF1000 Rig/Sails
- ↳ DF1000 Motor/Equipment/Electrics
- DF32
- ↳ DF32 General Topics
- ↳ DF32 Hull
- ↳ DF32 Rig/Sails
- ↳ DF32 Motor/Equipment/Electrics
- DF35
- ↳ DF35 General Topics
- ↳ DF35 Hull
- ↳ DF35 Rig/Sails
- ↳ DF35 Motor/Equipment/Electrics
- DF1200
- ↳ DF1200 General Topics
- ↳ DF1200 Hull
- ↳ DF1200 Rig/Sails
- ↳ DF1200 Motor/Equipment/Electrics
- DF40
- ↳ DF40 General Topics
- ↳ DF40 Hull
- ↳ DF40 Rig/Sails
- ↳ DF40 Motor/Equipment/Electrics
