I'm a new owner of an 800 swingwing - and i have rain water comming
in the cockpit floor locker - not from the hatch - it seems to come in through the holes in the hull where the alumunium tubes that hold out the wings, comes through. any ideas?
Water in cockpitlocker
- Your Country: Denmark, Hundige
- Your Country: USA, La Crosse/Wisconsin
WE HAD THE SAME PROBLEM IN OUR 800. THE WATER WAS COMING FROM THE HOSE THAT CONNECTED THE SCUPPERS (FLOOR DRAINS IN THE OUTER SEATING AREA) TO THE THROUGH THE HULL FITTINGS THAT ALLOW THE SEATING AREA TO DRAIN IF IT IS FLOODED BY A BIG WAVE, DRIPPING SWIMMERS OR RAIN. RADIATOR CLAMPS AND NEW 1 1/4 " SUMP PUMP HOSE FROM THE LOCAL HARDWARE STORE SOLVED THE PROBLEM. TAKE THE BIG DRAWER OUT AND STICK YOUR HEAD IN THERE, IT IS REALLY BIG!
