HONDA 10
HONDA 10
I presently have the original Yamaha 10 manual start, supplied as original equipment. Quornings now fit an electric start Honda 10, but I believe that the existing wooden pad on my 1998 boat might need modyfying to do this. Anybody know what the difference might be?
Also, has anyone fitted a power tilt version of the Honda 10 to their 920? Difficult to get hold of in Europe, but the dealers in the USA list them. The F boat website suggests that the mounting bracket size can sometimes be a problem. Anybody know?
Honda 10
My observation is that teh Honda 10 has a longer mounting bracket and the Df-920 mounting pad must be extended down past the hull-deck joint. That would require a fiberglass expert to do it properly, but it can be done.
I don't think it would be worth it to change to the Honda. You can still buy the Yamaha T9.9 HP in the US. http://www.yamaha-motor.com/outboard/pr ... specs.aspx
You can also buy a bolt-on electric tilt for any engine, from a maker called CMC. http://www.overtons.com/modperl/product ... 21204&aID=
Draken
Your Country: Sweden, Vaxholm
Honda 10 propeller
Post by Draken »
What propeller do you have, mine was fitted with a standard 4 blade aluminium 9 1/4 * 8. A fast calculation, 5500 rpm, 10% slip gives 14.4 knots. The result has been that my engine never gets more that 3000 rps and a lot of cavitation on the propeller. I had a hard time to get out of Helsinki in 12-14 m/s and waves - only 2 - 2,5 knots!!
I have now ordered a power thrust model from Honda catalogue 10*6 1/4 and with cupped blades.
Anyone with more experience??
buckle.roger
Re: Honda 10 propeller
Post by buckle.roger »
Draken wrote:What propeller do you have, mine was fitted with a standard 4 blade aluminium 9 1/4 * 8. A fast calculation, 5500 rpm, 10% slip gives 14.4 knots. The result has been that my engine never gets more that 3000 rps and a lot of cavitation on the propeller. I had a hard time to get out of Helsinki in 12-14 m/s and waves - only 2 - 2,5 knots!!
buckle.roger
honda 9.9 propeler
What results have you got from your new high thrust 10 6 1/4 propeler on your 920
buckle.roger
Hi I would like to know how your new propeler performs, is it the correct size for the honda 10 hp
buckle.roger
Can you give me the outcome of your new prop, is it the right one as I have the same problem, I have no idea why people put engines on a boat with the wrong prop on it, but there you go, its life
buckle.roger
prop size for a 920 wirg honda 10 hp
Can some one please let me know what is the correct size of propeler for the 920 with honda 10 hp, the standard is totaly over sized
