Repairng the trampoline
I need to get a trampoline repaired, can I take the trampoline off and then put the wing back out for balance, or is the trampoline structural in providing support?
And why is the manual from Quoring so limited!
Christine
Christine
- Your Country: Denmark, Hornbaek
Re: Repairng the trampoline
Hi Christine.Christine wrote:I need to get a trampoline repaired, can I take the trampoline off and then put the wing back out for balance, or is the trampoline structural in providing support?
Christine
Last year I took my trampoline off and i left the wing out all the time. I did not sail whitout the trampoline.
Best regards
Michael Riis
DF800SW - 265
Christine;
I posted this a while ago on the General Forum.
"I just happened to send mine out yesterday to Sunrise to get repaired for just that same issue. It seems the tramp material is in great shape, just the bolt rope and seam where it attached to the main hull was trashed.
Talk to Richard at Sunrise. http://www.multihullnets.com/
The price for new tramps was about $1880.00 - ouch! He didn't quote me a firm price yet on the repair, but from what I described to him of what needed to be done, the repair was going to be in the neighborhood of $250.00.
I'll update this thread when I find out more."
Ted[/quote]
By the way, they came out great.
And at $250.00 to repair both tramps, it was the way to go.
Good luck
Ted[/quote]
Good luck
UV degrades the trampoline threads
The issue that causes problems first is UV. The trampolines are sewn with polyester thread, which has about a 5-7 year life, depending on location and winter storage.
You can buy Gore-Tex thread (trade name "Tenara") that is not as strong (for the same diameter) as polyester but does not degrade. It is very expensive (a large 875m spool that is enough for two 1200's is about $150 USD), and I recommend you get the heaviest weight Tenara you can find.
As preventive maintenance, I bought the Tenara thread this year and had a sail maker back-stitch (over-stitch) the existing polyester sewing on my 7-year-old nets (using a zig-zag stitch, which is less likely to weaken the underlying net fabric). I expect the nets to last at least another 7+ years without failure, although I might replace cables in a few more years (also as preventive maintenance). Cables should be inspected regularly anyway, especially at the terminations.
UK Trampoline Repairs
Had a simialr problem to you guys, the tread went holding the tramp together.
Took it off (with the float out) and had it repaired by Mouse Sails in Holyhead.
They collected it, repaired it and dropped it back to the marina inside a week for £60.
I can't recommend them enough, they will be getting my business for a new sprayhood with service like that. (not on commission but maybe I should be!)
Tramp repair
I've got a DF1000.
I got tired of restitching my own tramps every 2 years, so I finally bought some GoreTex thread.
I restitched them a couple of months ago and am looking forward to several years of not having to redo this job.
(A sewing machine repairman)
