wind instrument for rotating rig
Nille
Post by Nille »
Looking for a wind instrument. Preferably with both force and direction(s).
Are there any wind systems that can compensate for mast rotation other than tacktick?
Rotating mast wind instruments
There are a couple of manufactures making this sensor. Tacktik makes one, here is the link http://www.tacktick.com/products/produc ... sp?prod=82. They say they are not available yet.
Nexus had one out a couple of years ago also, see this link; http://www.silva.se/marine/
Be prepared, they are pricey!
Re: wind instrument for rotating rig
Nexus (Silva) does have a suitable system for this purpose. As output you will get apparent and true wind speeds and directions.
http://www.nexusmarine.se/marine/index.htm
Product ID: 22933-52 NX Start Pack 3
Price about 920 euros
Including wind transuder (wireless ), speed / depth instrument, wind instrument, log / depth transuder and CPU unit
Product ID: 69980 Mast Rotation Compensation Unit
Price about 680 euros
Nille wrote:Looking for a wind instrument. Preferably with both force and direction(s).
Airmar PB200 is one possibility to solve this problem. There are several instruments packed into this weather station.
http://airmartechnology.com/airmar2005/ ... age=Marine
http://airmartechnology.com/uploads/brochures/PB200.pdf
The price is about 1000 USD.
One problem with it is the need to calculate somewhere (external PC or something else?) mast rotating angle out of magnetic compass heading and GPS heading. The format of data is NMEA2000 or NMEA183.
For some reason Airmar technical customer service did not recommend PB200 for sailing boats, but they did not answer the question WHY.
Here is one more solution with PB200 and without external PC:
http://www.tecnautic.com/e-usd/wind_e02.htm
