trampoline maintenance
on my trampolines the plastic coating is worn off at some places leaving the webbing threads bare. Anyone ever tried to "re-seal" the coat?
Re: trampoline maintenance
Hi Nille, I would not recommend a re-seal. its hard to get a good seal with the "old" sealing material and is a difficult job. Better buy two new trampolines when your old ones need replcement. Bought recently two new trampolines for my DF800 for less that 750 euro/set made from the same material that professional racingcats use, strong and let water through so not to much tension on your beam during hard sailing. regards SoleiNille wrote:on my trampolines the plastic coating is worn off at some places leaving the webbing threads bare. Anyone ever tried to "re-seal" the coat?
