I am looking for an extra long tiller extension for my DF 800 fixed wings "Stress Free". It must be long enough to steer from the trampoline or even from the amas.
Are your extensions custom made or which mark sell them ?
Thank you / merci
Kenavo
Jean Louis
Extra long tiller extension
- Your Country: dinard britanny france
Re: Extra long tiller extension
I have a (two) telescopic Ronstan Battle Stick. The longest is 1530 mm - 2490 mm.
It works well even it is a little to short.
When i am steering in the cockpit i have a shorter Battle Stick 740 mm - 1210 mm.
It is easy to change between the two sticks.
I use to adjust the length of the telescopic tillers a lot.
Henrik
DF 800 SWR 175
DF 800 SWR 175
Fancy - but not realy usefull
Tiller extension - made an extra long one - just as a simple connection on the existing short tiller extension. It is a 2m aluminium tube – I store it in the boom.
It is long enough to sit on the ama and sail. But it feels akward. Too far away from mainsheet. I hardly use it.
So make a simple prototype and try it out first – it looks fancy to sail from ama – but it is not practical.
/Christian
/Christian
