CAD drawings
CAD drawings
I am about to draw AutoCad drawings of the hull and rig at the moment.
I have got only the original User's Manual drawings scanned to PDF format, but their quality is really poor and scaling in X-Y dimensions varies. I have spent hours to make measurements in my DF but it is quite difficult.
I would like to get more information about the dimensions and shapes of the hull, rigging, mast and interior.
Does anyone have better quality drawings (PDF, JPG, DXF, DWG...)[/b]
Thanks. This helps a lot.Jurij13 wrote:Hello Mika,
look here: http://www.dragonfly-1000.de/Dragonfly-1036/Deck.html
Greats Jurij
- Your Country: Germany, Bad Homburg/Hessen
CAD drawing modification
Helle Mika,
possible to let me have a dwg or dxf file?
Is it possible to use a "normal" trailer for the 1000 in germany?
I mean if the armas complete disassembled (2.5 to 2.55 meter)
thanks
Hans
thanks
Hans
Re: CAD drawing modification
[/quote]
According to my measurements the width of the centre hull is 2745mm so it is too much for trailering. The measured weight of my DF is 3119kg.
There was one Italian DF1000 for sale a couple of years ago with a special trailer equipped with hydraulic system to rotate the hull around the center line to get the width under 2.55m.
I am happy to send those files to you, just tell me your email.
