Hej
Jeg har købt en ældre DF 800 (nr. 92) som har en del gelcoat-skader.
Jeg mangler tip og data omkring gelcoat-farver til denne type.
Der findes jo en del forskellige farvekoder.
anyone?
mvh Per Ølholm, Viborg
Reperation af gelcoat - DF 800
Journalist og ejer af sejlerfilm.dk, som producerer videoer til bådbranchen.
Topcoat RAL 9010, and if you need to make it perfect you should mix some "ocra", to make it more "yellowish" (beaware that you only need to very very small amount of "ocra") and match better to the old gelcoat. You should also note that topcoat change color when hardened and it also change color in different way than the old gelcoat surface which has seen many years of sun light. So finding a perfect color is not that easy.
Interior is painted with RAL 1013. It should be perfect fit out of the box. If you find it hard to paint the interior in the way its done originally, use some silica with the topcoat...
Ex. DF800
