Removing Amas
Christine
Your Country: UK, South Coast
Removing Amas
Post by Christine »
We normally winter our dragonfly on the trailer with the amas folded in, but want to remove them this winter. Having trouble finding a spanner or socket that will fit in the space though. What does anyone else use to remove the amas and the best procedure that you've found.
If you have a youtube video, that would be great :wink:
Paul
Post by Paul »
Christine, if you have the swing wing Df800 it is pretty simple, you will need a couple of people to carry and move the amas after removal though. I used two open ended spanners, one to hold the bottom nut and one to loosen the locking nut, suitably sized ring spanners will also do. You will need to support the amas whilst you remove the two nuts, a couple of sawhorses or friends to take the weight as you remove the nuts. That's it, once the nuts are undone lower the amas off the bolts and replace the nuts and spring washers so you don't lose them.
good luck with it,
paul
Paul
Post by Paul »
I just found a nice video on Youtube showing how to remove the amas (link is on this forum by Mika Harku).
cheers,
paul
Christine
Post by Christine »
Thanks Paul, bought a suitably sized spanner and it came off a treat. Made cleaning a lot easier, don't know why we didn't do it before :)
