replacement pivot point "bearing plates" on the am
Doppelfrosch
Your Country: Germany Dortmund
Post by Doppelfrosch »
Hi there.
I have too replace the round, white plastic which are sitting on the amas pivot points.
Does anyone has done this?
What kind of material is it, or is there a better material to take instead of the original?
Mine are worn out by the sun.
Did someone got the drawings/measuremets for the 920?
Would be easier to get them water cut with cnc data.
Best regards Björn
DF 920 # 27, 1998
Canary Islands
Re: replacement pivot point "bearing plates" on th
Teflon PTFE sheet is the right material for these. UV resistance is good and it is low-friction. Nylon is NO good because of UV.
UV-resistance:
https://www.directplastics.co.uk/how-uv ... stics.html
Material:
https://www.directplastics.co.uk/ptfe-sheet
