Mk 2 centre board
Mk 2 centre board
Hi,
My Mk2 (no 91) has a problem with the centre-board down-haul. The board is splitting where the line passes into the board before being knotted off. This is makng the board hard to get down as it is rubbing on the centre board case.
I need to get access to this part of the board in order to bolt through and glue it. I imagine the two options are to drop it out from below or to take off the centre board case top.
The pivot bolt looks as if it is below water level so I guess I am going to have to dry out to do this job, but any advice would be gratefully received.
Cheers,
Andy
Cheers,
Andy
- Your Country: Austria
Re: Mk 2 centre board
Andy, no chance to come to the down-haul-access from the case top - it´s not enough space for Your hands. The pivot-bolt is easy to remove, when craned the boat, und You can lower the centre-board. I just did it last autumn without problems.
AndyMonty wrote:Hi,
Cheers,
Andy
centreboard downhaul lines frayed
The downhaul line on my centreboard is badly worn through to the inner core where it is tensioned on the rope jammer. Is the only way to replace the downhaul line for the centreboard, to crane the boat? Is it possible to have a diver remove the board in a couple of metres of water, replace the downhaul line and put the board back in the case? This would be a far cheaper way to do the job if it is possible. Any thoughts on this appreciated.
Hi Paul,
My boat has a perspex hatch in the top of the board case which when unscrewed gives you just enough room to reach down to the top of the board where the line is fixed. Certainly a lot easier than dropping the board out.
Hope that helps,
Cheers,
Andy
Hope that helps,
Cheers,
Andy
Thanks Andy, do you have a picture of the perspex hatch on your boat, can you do simple drawing of the way the two ropes are attached to the board with some measurements? If I can arrange a system like yours to access the ropes I will do it, much easier than dropping the mast and paying a crane to lift it. Thanks for your reply, there's a resident crocodile in our marina and I wasn't all that comfortable about attempting to dive on t boat and get the board out that way!
Paul
Paul
The photos appear to show the perspex inspection window about 4 inches back from the compression post Andy, and about 10 inches long? Would that be about right? Guess you removed the table top to cut the access hole, if so why not just remove the table top to replace the downhaul rope every 6 or so years and retain the nice varnished table top?
cheers,
Paul
cheers,
Paul
Hi Andy,
I am planning on taking the table top off this week and trying to reach the downhaul rope that way, your boat's previous owner must have added the perspex window as it is not an original piece of equipment. The resident croc is active at present so do not want to get in the water at the marina! On another note, I sometimes have trouble tacking the boat in a chop, end up "in irons" and either have to reverse rudder and try to steer her backwards until I can get forward momentum, or backwinding the jib to get her around. Any suggestions on tacking in choppy conditions appreciated. In smooth water she goes through 90 degrees no problem. Maybe easing the main off and backwinding the jib at the same time would help??\
Cheers,
Paul
Cheers,
Paul
- Your Country: dinard britanny france
Perpex window for centerboard inspection
Paul wrote:Hi Andy,
Cheers,
Paul
Bonsoir ,
I own a MK2 DF 800 N° 88 , and there is exactly the same window at the same place , so I think it is genuine equipment.
I have changed the two ropes ( up and down ) through this window at the mooring.
It is a test of skill and perseverance !
Kenavo J.Louis
Paul,
I can't claim any expertise with the DF800 wrt to tacking in chop as I have only had her for a year. My experience with A-Class cats supports your suggestions of easing the main as you go round, plus the other things such as looking for a flat spot to tack, getting up plenty of speed before going round, easing progressively into the turn to avoid loosing too much speed. Backwinding the jib should help if you are really stuck, and making sure you tighten it as soon as you are round (before the main) should help. The other thing I found with the A was having the mast raked back made it much easier to get stuck in irons, don't know if that is the case with the DF.
Interesting to hear that the perspex hatch is a standard feature on Mk2, Kenavo, I thought the workmanship looked a bit good for an amateur fix. It is a tight squeeze inside the case isn't it? I developed an extra joint in my wrists fixing the split in my centre-board in situ.
Andy
Andy
We took the table top off and were able to fix the problem of the frayed downhall, tight but doable. As to tacking in a chop, we just sailed 70 miles in 15 - 20 knots on the nose and did many tacks, (before the pivot bolt on the forward port ama let go, see my post under DF 800 hull issues dated Sat 27th August) easing the main as we went through the tack and backwinding the jib did the trick. Thanks for your input Andy.
Paul
Paul
