Bowsprit for DF920 R
Posted: Mon 08 Dec 08, 21:24
by Chris R
I have a 920 without a bowsprit, and the price quoted by Quorning seems very high. I'm thinking of getting one made up, but would prefer to measure all the kit on an existing boat. Has anyone got a 920 racing with bowsprit around Hamphire / Dorset that I could take the design / measurements from
920R bowsprit
Posted: Wed 31 Dec 08, 1:35
by David Hyland
Hi Chris,
You may already have solution but you are welcome to view Zoum!, a 2001 920R. It is moored in Ocean Village marina in Southampton. I believe the bowsprit is a standard Quorning fitting hinged so it can be swung upward to allow floats to be retracted.
Dave
DF920 Bowsprit
Posted: Mon 11 Jul 11, 1:07
by sjschweitzer815
I need to replace the bowsprit on my 2000 DF920. Does ay one have experience with building one? Experience with mounting a retractable sprit on the deck? Can you share your experience?
Re: DF920 Bowsprit
Posted: Sun 07 Aug 11, 13:24
by Ernst Fellner
sjschweitzer815 wrote:I need to replace the bowsprit on my 2000 DF920. Does ay one have experience with building one? Experience with mounting a retractable sprit on the deck? Can you share your experience?
Hi sjschweitezer815,
June 2002 i attached an bowsprit with anchor fitting and roller at the bow of my DF920R-57, see the pictures in the old forum (24. June 2002 ).
Since that time I wanted to build an retractable Gennaker – boom as the distance between original Quorning bowsprit-fitting and new fitting at the front end of the bow-platform is merely 30 cm. The boom should be retracted in the anchor-locker and pusched out for Gennaker-sailing. But cutting a hole in the fuselage caused me headaches and so I did this only several years later.
As seen in the pictures a stainless steel hose is fixed at the bow platform. Drilling the opening for the boom I did in two steps: First a pilot-whole with a very long drill ( > 80 cm), guided at the shaft by a wooden fixing, then cutting the hole with a key-hole saw, see picture, the hole saw guided by the long drill. Inside the anchor-locker a tube is laminated, reinforced by an stainless steel ring, all laminated to the inner fuselage wall. The boom can now pushed in and pulled out easily by a tackle with cam-cleat as seen in the picture.
The length of the boom is limited by the rear wall of the anchor locker, the effective/usable length of the boom is about 90 cm, measured from the original Quorning fitting to the front end. You could use a longer boom but then an additional hole has to be cut in the rear wall of anchor locker and the boom would reach into the cabin ( locker over the front berth). I didn’t do this and I’m satisfied with the relatively short boom.
The front- and end- fittings of the boom are the original ones from Quorning.
Re: DF920 Bowsprit
Posted: Sat 16 Jan 21, 17:06
by Jurij13
Hallo Ernst, hast du eigentlich noch alte Unterlagen/Zeichnungen über deinen Bowsprit? Würde mich darüber freuen. Grüße Jurij
