High Tech sail set
Posted: Fri 31 Jul 09, 9:33
by Mika Harju
After a lot of trouble I have finally received and tested my new sail set. The head sail is about 24sqm membrane sail with 30Technora and 70Carbon yarns. The main sail is about 49sqm membrane sail with 30Technora and 70Twaron yarns. The total sail area was increased by about 12sqm.
Boat speed has increased 1-2 knots especially in light air and tacking angle is 5-10 degrees better.
Sailing is much more fun now!
Attached you will find a couple of drawings and a photo of the set:
DF1000R-SailSetV6Model.pdf
DF1000R-MainSail49SqmModel.pdf
DF1000R-Genoa24SqmModel.pdf
Posted: Sat 01 Aug 09, 2:11
Mika,
Sweet set of sails! Really high tech! It is always surprising on how much better performance you get out of a new set of sails! May you put many a happy mile on them!
Posted: Mon 03 Aug 09, 20:26
by Christian
Cool - looks great, nice speed too.
Ever tried the 2:nd reef?
/ Christian
Posted: Fri 07 Aug 09, 10:15
by Mika Harju
Christian wrote:Cool - looks great, nice speed too.
/ Christian
2nd reef has not yet been in real use, just tested it. My basic idea was 1st reef to be enougth and the 2nd reef is just for survival use. In membrane sails one good point is the sail keeps it's strength and shape when reefed. New set of yarns start from every reefing eye.
In heavy weather I think there will be some problems to get all the sail placed somewhere at the boom. In my previous 39sqm main I had 3 reef lines, but the 3rd one has never been in use.
front sail genoa
Posted: Fri 09 Jun 17, 14:04
by danceswithwaves-DF1000
Hello Mika, and df1000 owner,
I lost old genoa (stolhen!) do you have more precise dimension of it?.
Best regards
Re: front sail genoa
Posted: Mon 12 Jun 17, 9:58
by Mika Harju
Mine is DF1000R equipped with taller rotating mast. Mast profile length is 15008 mm. Attached a drawing of my jib and mast. If you need a ready designed 3D IGES file of the jib for your sailmaker just let me know.
DF1000RJibDim.pdf
front sail genoa
Posted: Mon 12 Jun 17, 22:23
Thank you Mika, i will compare length of furling system and iges may help my sailmaker.
email: ericetlaurence.dubois@gmail.com.
best regards
