Autopilot
Posted: Wed 09 Jun 10, 8:58
Autopilot stopped working. I examined all instruments, excluded ”software” problems, and found that the drive unit was not responding. Expecting that a fuse had blown I started searching for fuse placement. It appears that the fuse is placed inside the Jefa drive unit box. This box is placed under the deck of the cockpit behind the chain to the steering wheel. Not so easy access: With the head and nearly all my trunk down in the engine room I get close to the box and found entrance of wires. I had to screw up 4 small screws on the top cover. These screws needs a star screwdriver, and even I used the proper driver and handled with care, two of them broke (take care – stuff is really soft!). It was impossible to screw them up even I tried with different hard-metal tools. No way, I had to demount the entire autopilot drive unit – only 4 nuts… but on very, very long screws, where 2 of them are hidden behind the box = not visible. I demounted arms to the drive unit and with one (left) hand, the head and trunk down in the engine room slowly bit by bit I unscrewed all nuts. Despite that the unit is quite heavy it did not glide easily from screws because of very tight shock absorbing rubber tubes in box’s holes, so it required quite a lot of press to got it down. It took about 1½ hour of hard work in sweat. I got the animal out and was lucky to remove broken screws form the top cover without hammering and boring. The fuse is on the red wire just after it comes to the box. *@! can happens again, so I decided to move the fuse outside the box. Mounting the drive unit back on the place is much more challenging job: through the entrance to the engine room, with your left hand under the cockpit deck you have to lift this heavy box up towards screws on the roof of the cockpit, align them properly, press so hard that the rubber tubes will “glide” on screws and then, with the same (left) hand screw nuts on. Well, good luck! I used wooden wedges under the box to lift it gradually up and after 1 hour work the unit was on place with nuts on. Then, only replacement of the arms and finale grande!
Other methods of access for replacing this fuse: Remove the wall between engine room and cabin, and do it from the cabin site; or: remove Volvo engine out of the room and turn the boat upside-down…
To those who order a new 35’er: order Jefa autopilot drive unit with the fuse outside the box – in such case exchanging the fuse will take less than 1 minute.
Sunny and windy summer,
Mario
Photo 1: Jefa autopilot drive unit hidden under the cockpit deck
Photo 2: Top cover of the drive unit where the fuse is placed (screws are already replaced)
Photo 3: Fuse prepared for mounting outside the box
Mario
