Choice
Posted: Wed 08 Dec 10, 10:16
by clarivoile
On a D 920 Extreme, with already asymmetric chute, what would you advise between a Genaker and a "code 0"
Posted: Mon 31 Jan 11, 12:55
by roby
gennaker if you sail in a medium strong wind, code 0 if you sail in a very light condition
You need a #1 light air Genoa
Posted: Mon 31 Jan 11, 13:27
Neither. You already have downwind deep reaching covered with your asymmetric. You need a flatter sail for close reaching, and because of the speed performance of a trimaran the apparent wind moves forward more than monos... So you're close reaching even when the true wind is 90-degrees on your beam. Code zero and gennakers made for monohulls are too full cut for upwind sailing because of the apparent wind's forward shift.
Ask your sailmaker for a #1 light air Genoa to mount on the sprit with a continuous line furler (CLF). Sheeting point should be a turning block attached to the lifting eye on the aft beams. They may call it a code zero because of the fabric they use and CLF, but make sure they consider that it needs to be cut like a genoa -- not as full-cut as a conventional code zero.
Thank you
Posted: Wed 02 Feb 11, 10:56
by clarivoile
I think you're perfectly right.
But what do you call full cut compare to "genoa cut"?
I've ordered both genaker and code 0, but still no measurements done yet. The code 0 fabric will be CZ60 2,6 oz.
i ordered the genak as well as I have been told that it was more efficient than the assymetric spinaeker
Thank you for your advise
Re: Thank you
Posted: Thu 03 Feb 11, 10:52
clarivoile wrote:I think you're perfectly right.
Full cut means there is more of a rounded balloon-like fullness to the sail. Genoa is more flat and has less bulge when it fills with air. It should be clear if you tell your sailmaker you need a #1 genoa made of CZ60 and using a continuous line furler. (Not a typical code zero)
Considering you already have the asymmetric I don't understand why you would order the gennaker. If the asymmetric is large enough I doubt the gennaker will perform better downwind. You don't need three light-air headsails, in my opinion two will be enough: One for windward close reaching/beating and one for offwind.
Also, you should rig your barberhauler to work with your #1 genoa for when you sail a bit deeper.
Tanks again
Posted: Thu 03 Feb 11, 11:11
by clarivoile
for explanation of full cut and genoa cut. That's exactly what I've asked for.
I fully agree with your proposal. It will be like a light genoa made of CZ60 2.6o
A trimaran racer told me that he could verify that the gennaker was giving better performance down wind than the asymmetric except light wind. He thought the luff was more efficient.
Anyway, it's easier for use when I'm single handed (80% of my sailing), when it's windy, and could be use as spare whenever I've a problem with my asymmetric like just before the last regatta...
Posted: Thu 03 Feb 11, 12:42
One more thing - many installations using a CLF have a problem with the furler spinning (if it's mounted to the tack line) causing the furling line to wrap. If you mount it to the sprit using a shackle so the furler won't spin that will not be an issue. You can leave it mounted and rig your sails to detach quickly from the top of the furler, making it easier to switch sails using the one furler.
The only down-side to that is you won't be able to use the tack line as an adjustment.
Good point
Posted: Fri 04 Feb 11, 12:55
by clarivoile
but I don't really understand. If you mount it directly on the sprit with a shackle, how do you change he sails? You need to reach the sprit end each time, don't you?
Re: Good point
Posted: Fri 04 Feb 11, 15:03
clarivoile wrote:but I don't really understand. If you mount it directly on the sprit with a shackle, how do you change he sails? You need to reach the sprit end each time, don't you?
The sprit on a 920 raises. Just release the bob-stay and pull it up toward you.
Posted: Fri 04 Feb 11, 21:39
by Stefan Kolmodin
I'm sure our local sail maker Gransegel can advice you on - and more than happy to deliver - multihull specific sails since they're experienced and fanatic DF sailors/racers themselves. Give Mats Johansson a call before decision/order 8) https://www.gransegel.se/dragonfly.html
Yes
Posted: Sat 05 Feb 11, 13:44
by clarivoile
I knew that that was the basic solution, but I was looking for something faster.
Thanks any away for the heads up on that point.
Stefan, I already contact them when you gave me their email, but they didn't look that interested.
Not a problem, I've got lot of sails maker here. But it's nicer to discuss that type of thing here
Thanks everybody
Enjoy your week end.
Posted: Sun 06 Feb 11, 12:34
by Stefan Kolmodin
OK, no worries - up to them
I only guessed that there's not that many good sail makers with a lot of DF-specific experience - i.e. have tried different designs and found out what's working best for each model etc.
Downwind sails
Posted: Tue 08 Feb 11, 17:48
by Mats
Here is the quote if someone is interested.
https://www.gransegel.se/Dragonfly/DF920DWQuote.html
My contact information ;
https://www.gransegel.se/design.html
Posted: Wed 09 Feb 11, 5:41
(I just changed my post) The screecher looks good.
In my opinion that's all you need, unless there's something wrong with the asymmetric you already own. See my posts above.
yes
Posted: Wed 09 Feb 11, 9:55
by clarivoile
i do agree. I'll just take the gennaker in addition as a spare for the sym spinnaker, and for ease when playing around for fun on my own in the area
Here they are
Posted: Tue 26 Apr 11, 8:24
by clarivoile
as expected, the genak doesn't give much more than the assy.
But I've found difficulty to roll this genaker. The bottom rolls while the top don't till the very last end, resulting in the top unrolling on its own as soon as going upwind :(
not really happy
Posted: Thu 12 May 11, 9:01
by clarivoile
with the code 0.
I should have followed Mats offer :(
Re: not really happy
Posted: Thu 12 May 11, 16:12
by EarthBM
clarivoile wrote:with the code 0.
Can you elaborate on what you don't like?
unfortunately
Posted: Fri 13 May 11, 9:20
by clarivoile
the code 0 is more full cut than genoa cut.....although my requirements were clear and thoroughly described :x
May be good for monohulls
Need to sale it, now!
