The lower support bar is installed with three M10 screws. Two at the front are welded to the steel bar and the nuts are inside, but my problem is the third one at the stern. There is a M10 hexagon head screw but I do not know is there an ordinary M10 nut or a M10 threaded steel plate or what inside? Whatever there is it is covered with a lot of classfiber.
DF1000 and DF920 should have similar construction.
Please see attached drawing and photos:
Drawings: HowToRemoveRudderChassis.pdf, HowToRemoveRudderChassis2.pdf
