Supports for dry winter storage DF35
Posted: Thu 20 Aug 15, 22:00
It is recommended that the DF35 is supported at the water stays for dry winter storage. I can have a frame built to the dimensions of a trailer (a drawing has been kindly provided by the yard).
However, I do not have the actual shape of the (wooden) support blocks that touch the hull (w/ carpet). I note a step change in the hull at the water stays.
Does anyone happen to have dimensions of the wooden blocks that fit the DF35 hull at the water stays? I can then prepare these ahead of the lift out.
Secondly, what are the practices of covering the boat when outside during the winter? (tarpaulin?)
