Genoa furling system jammed. Fixing instructions.
My furling system top bearing was not working properly and finally it jammed totally. The seal of top bearing unit was broken and upper bearing was full of rust and did not rotate at all. There is possibility to get the whole rig down if the thread between upper and lower part of the bearing box opens while furling. If you need instructions and spare parts list please send me an email.
This happened on mine also. Had to go up on the chair to get it down. Bearings were shot. My opinion is that the furler is undersized.
It was an easy fix to replace the bearings. This is on my upgrade list - someday!
Re: Genoa furling system jammed. Fixing instructions.
I would like instructions and spare parts list, but I can't find your email link.Mika Harju wrote:My furling system top bearing was not working properly and finally it jammed totally. The seal of top bearing unit was broken and upper bearing was full of rust and did not rotate at all. There is possibility to get the whole rig down if the thread between upper and lower part of the bearing box opens while furling. If you need instructions and spare parts list please send me an email.
Bo, please forward this message to Mika.
Steve:
Is yours a Pro-furl unit? If so give them a call (look on their website for your local dealer in Washington state). From what they told me a couple of years ago, it is a common problem, relatively cheap and a easy fix. They have the directions on how to do it. The hardest part was taking the sail down!
I don't know for sure exactly what it is, as I am the third owner of the boat.
It doesn't look like any profurl unit I've seen before; no telltale chartreuse anodizing. At any rate, I'll look around for profurl info.
The furler is getting harder and harder to use but if I ease the cap shrouds it gets easier. It sure sounds like that's the problem. Do I have to drop the forestay? The boat's at the dock in my back yard so I can take my time fixing it.
- Your Country: Austria
I had exactly the same problem at my 800 this year and could fix it by cleaning the bearing properly and mount it again with a lot of high density-grease. The furler is still not working well but it works. I can furl the genua by releasing the backstays, furling is possible which was not before.Mika Harju wrote:My furling system top bearing was not working properly and finally it jammed totally. The seal of top bearing unit was broken and upper bearing was full of rust and did not rotate at all. There is possibility to get the whole rig down if the thread between upper and lower part of the bearing box opens while furling. If you need instructions and spare parts list please send me an email.
I suppose that the bearing at the bottom is also damaged and I will do the same with it before setting the mast in spring.
Steve; I didn't have to remove the forestay. Just disconnect the forestay at the connection at the bow, you can then slide off the lower drum and then the upper bearing drum. Just use a halyard or two to take the load off the forestay before you release it.
But never forget doing this!tpaliwoda wrote:Just use a halyard or two to take the load off the forestay before you release it.
Never forget...
This is probably a little off topic, but several years ago a man with a 5 year old very expensive 41 foot sailboat decided to replace all his standing rigging while the boat was in its slip at the marina. He dutifully removed the upper shrouds, the forestay, the backstay and the lower shrouds on one side. You guessed it, the deck stepped mast fell over on the next 3 boats!
Truly a "What was I thinking?" moment!
Top Furler Fixing Instructions
I've now added the photos to Mika Harju fixing instructions.
Thanks for the photos and part numbers!
Recently, I took down the forestay and found the same thing, an improperly placed thrust bearing. The grease was mostly gone, the top bearing was really bad and rusting, the lower bearing was better due to having more grease, but was still in need of replacement, and the thrust bearing was somewhere in between. I ordered replacement roller bearings, but was unable to find a part number for the thrust bearing. Being that I've reassembled it (and added a couple more set screws to the housing for good measure) I'll try it out with the old thrust bearing.
The hardest part of the whole ordeal was finding someone to run me up the mast.
Bartels furler system
My boat has a jib furler made by http://www.bartelsgmbh.de/rollfockindex.html
Probably the same furler...
I've got a tall rig on hull #15.
The upper swivel got my attention a few years ago, but I have not yet gone through the furler.
It's probably the same as yours, but I can't get a handle on which furler I have.
It's a one line furler, s.s. but how can I tell which one it is?
Do I first have to pull it?
TIA,
TIA,
Definitely NOT a Profurl.
I wish it was.
I had Profurls on my previous boat, a Lord Nelson 35.
Re: Definitely NOT a Profurl.
Atttached you'll find a couple of photos of my furler. I hope these help you. This is Bartels Standard IV.
and the pdf file : FurlingFoilOriginalBartelsModel.pdf
- Your Country: Sweden, Mariestad
The same problem
I now have the same problem as you had 13 years ago. How did you do to open the bearingbox? I can´t open my.
Re: The same problem
The upper swivel body is assembled by using glue to prevent it to opening. Use heat to melt the glue and if necessary you need to use plumber's tools to open it. You'll damage the surface then but there is no options if force is needed to open.
I replaced the original Bartels system about 10 years ago with one-off design by myself. If you're interested I could advise you to build one too.
A couple of 3D Cad screenshots:
( Bo will add these)
