First the floats were brought inside for painting......
Unfortunately I quickly discovered that there was quite a bit of water intrusion into the laminate.... The hulls are laminated, the inside fiberglass layer is porous, there are now leaks around the various hardware pieces and there is no ventilation in a large portion of them.......ergo.....rot.
So, first things first, remove the paint. I'm tired of getting the anti fouling all over me and am also ready to get rid of the "artwork". Once the hulls are clean I will build the cradles that will be part of the trailering system, and then I will turn them over and most likely cut out sections of the deck and start making things right....
