Loose nuts on folding hinge
buckle.roger
Post by buckle.roger »
Ok this MAY be clear to you guys but I have only owned a Df for one year and it is a big learning curve from other boats.
~So I have just found that 50% on the bolts holding the folding hinges were loose on all 4 corners.
I dont know if there is a recomendation to tighten these but I would say go out and do so if you have not checked them this year.
roger
Ahhh the joys of maintenance! That is why it is called maintenance and not repairing.
I make it a point, every year before the boat goes back in the water to tighten all nuts and screws. It is always a surprise on what came loose over the past season.
roby
Your Country: italy, brescia, garda lake
CAP nuts
Post by roby »
Can i change the CAP nuts of mine with nylon lock nuts ?
Re: CAP nuts
roby wrote:Can i change the CAP nuts of mine with nylon lock nuts ?
That's interesting. Mine never come loose, but they all ARE Nylock nuts.
roby
Post by roby »
this year I change all the nuts, i found some screw short.....see the picture.
